Icon 1/4" Ratchet - Reducing Backdrag
Komet
WA
Hey everyone,
My venerable Craftsman 1/4" ratchet started skipping teeth recently, and with rebuild kits going for $20 on ebay, I figured it might be time to upgrade to a fine tooth unit since I'm usually in a tight space if I'm reaching for 1/4".
I've been curious about the Icon line, and have had a Pittsburgh Pro 3/8" flex head that has done me well for several years (it got floppy but works fine), so I picked up an Icon 1/4" fixed head ratchet. It's a nice ratchet, except holy moly it had a lot of backdrag. Enough that it was giving me some grief on some smaller fasteners, so I decided to see if I couldn't 'smooth it out' a little.
I chucked a 1/4 nut driver backwards in my drill, then used my Craftsman thumbwheel deal that has hex on one side and square on the other as an adapter to the ratchet, and then spun that sucker on high speed in 20 second bursts for both directions. I probably did that 4-5 times, letting the ratchet cool down each time, and I'm pleased to report the backdrag was significantly reduced! I had to revisit the same fasteners that were giving me trouble before, and I had no issues.
Anyway, thought I'd share my fix with you guys in case there's someone else out there with a ratchet that needs a little electric finesse.
Vpick001
Oh nice! I never gave mine a chance to wear in, the back drag was just way too much. I’ll give this a go, thanks for sharing.
Snapped-off
Indiana
Is it lubed? The ½" icon I bought was dry inside. I put a touch of super lube in and it was quite the difference.
lardy1
I "break in " most of my ratchets by spinning them with a drill. It makes a big difference in some. The much maligned LP90's benefit greatly from use and this speeds up that process.
I use long extensions and apply side pressure which seems to help break in the gears and pawl.
Mr_B
Reading
I don't see much appeal in ICON ratchets as plenty better mid priced options, the roto heads are fairly decent buy though .
