Simply list it with the known info and a mailing cost. With a that small of a loop, it's going to be something that is under 14".
That is almost a dead ringer for most 4x6 horizontal bandsaws. Correct depth and width. Most of them are 64.5 to 65 so a 66" blade should fit.
Let's give it a day or so - if nobody else has the saw this goes to and you think you can tension it up, then it's yours, cost of shipping.If no one wants it, I may be able to make use of it.
Seems to match the specs of the blade I last bought. It's pretty used up by now![]()
Listed as 66" in the title, 5'6" in the body of the post: https://www.garagejournal.com/forum/threads/starrett-66-bandsaw-blade-free.540975/Did you list it as 5'6" long or as 66" ?
Band saw blades are generally listed by the inches.
This forum.Here, as in this thread, or this forum? I listed in the classified section of the forum here back in December.
Now I'm curious, did they tell you what it fit?Thanks for the suggestion - I posted this on PracticalMachinist.com and someone responded within an hour; the bandsaw blade has a new home.
What band saw?Ah dang.
My bandsaw would've used it.
What band saw?
They are relatively inexpensive, and you can have them made up to the exact length you need:A 20 year old HF model.
Blades are readily available, that's a non-issue. Just never tried a premium blade like the one posted.
