Id help!!??
ekegelmann
Northville, Mi
These we on the bottom of a toolbox i bought and im not sure what they are for or called, can anyone help? Thanks
E
ekegelmann
Northville, Mi
a few more.... any help would suffice.
zkling
What happened to your long thread?
I'll throw you a bone, brake caliper retract tools for calipers with internal parking brakes.
Indicator holder for mill.
jakemac
New England
The last item (that looks like a ViseGrip) is a hold-down tool. I use one on my drill press, but you could also drill a hole in your bench and use it there as well.
E
ekegelmann
Northville, Mi
ive been posting items there for awhile and never getting responses, im working on cleaning out a toolbox today and needed some quick answers....thanks for the help!
LB-1911
Northwestern Il.
:dunno:
Picked this craftsman 315.27830 6 1/2" electric hand saw up today, its very heavy. Anyone know when they made these as i cannot find a date code etc.
sykou
Golden box type tool is for retracting brake calipers. They still make them today. Google "disc brake piston tool". It is similar to the round one you have but the block style is used with a ratchet instead of a clamp tool. You need to apply pressure by hand and turn your ratchet at the same time. The multiple faces are spaced differently to accommodate different caliper piston sizes. The Pistons that require a rotation while compressing are determined by having specific holes in the recess of them 180* apart. These holes are what the tools fit into to allow the user to rotate the piston.
The round style one you would use it with an assortment of adapters and a specific brake caliper tool. But in your case since it has a square provision for a ratchet I believe it is just another variation of the block style type.
E
ekegelmann
Northville, Mi
Very cool and helpful. Thank you!!
Sent from my SM-G920T using Tapatalk
