dr_clyde
We had a few hundred 3/8-16 holes to thread for a customer project the other day, so I decided it was time to invest in a nice tapping head. This is a Procunier 3E with a #3MT input. It's rated to tap holes from #10 up to 1/2" and up to 1000 RPM.
This thing is so nice! Saved HOURS of time tapping these caster plates.
If you've never seen or used one of these, it basically is a fancy tapping chuck that has some gearing and clutches inside to allow you to auto-reverse the tap just by lifting the quill handle. It also speeds up double in reverse to make it faster.
Simply turn on the drill press in forward and leave it there. Tap the hole, and then just lift up on the handle and the tapping head will automatically shift the output to reverse and speed the tap out of the hole. It has an anti-rotation rod on the back that touches the column to keep it from just spinning around and around.
