Ideal electrical layout?
Lakeozark
lake ozark, MO
I am attaching a layout of my garage - It is being framed and roofed right now.
My G Contractor quit on me as he screwed me on the bid -So I am now the GC and have no clue about electrical.
I need to save money so I need to do the ordering of parts, material, etc.
Any ideas on a typical layout for electrical on a garage similar to mine?
# of electrical outlets? 2 or 4 gang? Obviously I am going to have several near the workbench, but anything some of you maybe WISH you had done but didn't?
4' high on electrical boxes all around the garage every 10'?
I am putting fluorescent fixtures on the 12' ceilings so I am going with about 20-24 4' T8 units. How many can be done "daisy chained"?
I will have an electrician complete the project - but I want everything sitting there and ready. I have my laborers that can rough the boxes, etc.
Any thoughts or ideas are appreciated.
Sworks120
I went with double gang boxes every 4' around the entire garage. One side was wired for 15A, the other for 20A....it is overkill by some but I never have to string extension cords. I also installed three outlets in the ceiling, one for the opener and the other ones for cord/light reels. On each of the three walls I have 4" boxes installed and wired with 8/3 for future use. Your lights will most likely have to be on two breakers as you can only have 10 devices per run if my memory serves me today. I also wired 5.1 surround sound and a place on the wall for a plasma, again all just in case my dreams come true. You may want to consider ethernet outlets if you have that option in case you wish to have a shop computer for looking stuff up or streaming music, etc.
TWX
Phoenix
When I wired my old work area outside, I put two circuits on the one wall, each 20A, where the double-wide outlets had one outlet from each circuit wired in. I did this so that if a couple of people were working it wouldn't mean that both were cut off necessarily if one went overvolt.
My current shop has some surface-mount conduit with a single receptacle every foot. There are two circuits worth of this, one going one way, the other the other way.
I plan to put a GFCI protector on to each circuit, but I haven't gotten around to it yet.
jbs
NW AR
I have duplex receptacles every few feet. I used multiple circuits, and alternated outlets on each circuit. I also color-coded the outlets by circuit. If you are going to drywall, I also recommend putting either the top or the bottom of the box at 4' height. That way you only have to measure/cut one row of drywall. Some pros might also recommend keeping the boxes away from the seam to make taping/mudding easier, but I **** at it, so I'm slow no matter what.
Edit: Forgot- for the lights, a continuous load must not exceed 80% of the circuit capacity, so 16A (16A*120V = 1960W) for a 20A circuit. Calculate this based on the actual draw (look at the ballast) of the lights you'll use (this will be somewhat greater than the 32W/bulb rating).
larry_g
oregon
Don't forget outside lighting for the door ways. Circuits for the door openers. Outlets high up for neon or other garage art. I left the wall open above my panel with a screwed on cover so that I have easy acess to install additional circuits as needed. Have you lanned outlets outside for weed trimmers, vacuum cleaners, or whatever. If your building a workshop then plan power to whatever tools you desire, aircompressor, table saw, welder, mill, lathe, three phase converter.
lg
no neat sig line
brewchief
Talk to your electrician before you go buying a bunch of stuff, some will not work with product they didn't supply. If they are OK with you supplying materials they should be able to give a pretty good list of what's needed.
I don't know many electricians who want to do only part of a job, most will want to do it all start to finish. If you want to save a buck see if they want you to drill out any studs and do basic grunt work. Giving them a clean, swept out space to work in will also cut down on time and thus cost.
You may want to keep your wall outlets just above 48" so if you have a sheet of plywood, drywall or whatever leaning against the wall in the future the outlet isn't blocked, this is of course dependent on the buildings future use. I would consider it a must in a woodshop but not a big deal in an auto shop.
L
Lakeozark
lake ozark, MO
i didnt think of extras up high for later...would like some neons someday. great idea
also didnt realize A*V=Watts...been a long time since electronics class in the military.
I will mainly be working on older cars and jeeps so i doubt I will need too much special equipment.
i plan on a ceiling (eventually), think I should mount the T8's on the rafters or hang them until I get that up?
I will have an airline as well as a 2 gang in the ceiling for drop over where I will be working so I will need to factor that as well.
Great ideas so far!! Thanks
