I just did this. I made a temp booth at home in my driveway using the structure from a Harbor Freight portable garage. I had an old easy up cover that I used for the top and I used heavy mil plastic around the sides and because I needed to set it up and take it down quick I just used a pile of spring clamps and made sure that everything was pulled tight to the frame and weighted the bottom to the driveway. I even made a bank of fans to put at one end with furnace filters attached, but didn't end up using it. Wish I would have. I blew out and hosed down everything, especially the driveway before doing any paint or prep work. I have crappy old asphalt and can get away with just letting the paint settle. If I were doing it on a nice drive or IN a garage, I would just use a sea of cardboard. I've done this in the past and it actually wasn't bad. Just piled up the cardboard and pulled it out when I needed it. Easy cleanup.
I did this work on sunny days and the booth got between 90 and 100 degrees. The cover was a dark color, so that kind of helped build up some heat, it seems.
I recently saw some do all of these same things using an old easy-up frame. And it turned out to be one of the nicest paint jobs I've seen on a very high end car.
Note: Dust, debri, and bugs are pretty much inevitable. Assume you will be color sanding and apply paint accordingly.
Note #2: I also used a supplied air respirator and it helped the comfort level tremendously! The one time I painted in the booth without it, I probably knocked a couple years off my life.
