Ideas for heating garage and attached studio
danofthesound
Hello All. I'm hoping that someone here will be able to help me work towards a solution for heating my garage, which is currently split into a workshop up front and a separate studio room in the back. All the "dirty" work happens in the front bays, and the back studio (to be wife's full time work area) is "clean". Some details:
1. Existing detached structure, poured slab floor, 22'x25'.
2. Insulation is on the way - 3" of closed cell foam in the walls, R50 blown-in for ceilings. 2 new 9x7 R16 garage doors planned.
3. There is a 2x4 wall with man-door between the workshop and the studio. The studio also has it's own man-door to outside. Plan is to spray foam this dividing wall as well.
4. Back studio is approximately 8'x22', and needs to be heated year-round. The workshop doesn't get used all that often in the winter, but it would be nice to have heat when I want or need it for projects.
The long and short is that I'm trying to come up with an appropriate heating solution based on the situation. I need the studio above freezing all the time and quick and easy heat when required. We have propane in the house already, adding another tank/appliance isn't an issue, but I'm not sure what type of setup is best given the divided space with different requirements.
Any thoughts or insight greatly appreciated!
PS - wife is moving into this space of her own free will, promise :pimpflash. Need more room for the kiddies in the house.
JakeKohl
Greenville, SC
what part of the country are you located? Your outside winter/summer conditions will affect any and all recommendations.
jumpingryan
Ontario, Canada
I live in Canada in similar climate....
I would say small electric baseboard for the small area.... Cheap and easy to install...
Then propane Sterling Garage Guy heater (my favorite brand cost comparable to others) for the larger space.
There should be some migration of heat radiating... That might allow you to turn down the more expensive electric in Ontario most of the time.... And leave the propane on.... However, propane is sometimes comparable to electric in some areas.
I heat my garage and house with oil myself.
Good luck.
I would seriously consider some kind of raised floor for the studio such as Dricore. The air gap created by a raised floor will prevent the cold from the floor from seeping in. You could put an electric heated floor over this, but I think it would be expensive to operate.
The simplest solution is 2 independent propane fired heaters.
Jackfre
N CA
Your wife's are should be a Rinnai EX11or 17. The 22 for the remaing shop area. Modulating gas valve and blower, programmable stat built in and they are QUIET. For a garage shop the noise isn't as much of a deal. For her space it is. Www.rinnai.us
