Hey guys,
Long time reader, first time thread-starter. Bear with me here, because this is long and "explainy."
I bought a house this spring that came with an 18x22 garage. It's no Garage Mahal, but it's heated, insulated and wired for 220.
Anyway, during the home inspection prior to purchase, the inspector noticed that the garage's front wall was problematic. It's literally just wooden walls on a concrete slab, meaning that the wood technically extends a couple inches under the gravel grade on that one wall. The inspector suggested that water could leak under the wall during a big rain. It was a killer house otherwise, so I figured I'd take my chances and cross that bridge when I got to it.
Well, the big rain came tonight and that front wall leaked quite a bit. So, something has to be done.
Now, my savings took quite a beating to buy this place, so I'm not in a position to get too crazy in terms of adding a concrete pony wall or anything. I'm hoping I can come up with a semi-temporary solution to drain water away during a downpour. It's not a problem during normal volume rain.
I was thinking maybe I could dig up the gravel in front of the wall and put in a run of 2" ABS with numerous small holes along the length of the wall and then use that to drain water safely away. If I sunk the ABS under some clean gravel, it seems that I could prevent the ABS tube from getting plugged up with leaves and ****.
Any thoughts or other ideas? See the attached pictures for more detail.
Here's a picture of the leaky wall. As you can see, the siding extends below the gravel grade.
Here's how far down the wall extends. It's about two or three inches.
Here's what I found inside after a pretty solid rain storm tonight. Mercifully, nothing got damaged.
Thanks!
S
Thanks!
S
