Ideas for separating Ranger R980 tire changer gearbox / transmission case halves
Relax
GTA, Ontario
The tire changer needs new bearings (actually needs a new top case half since it's cracked, but that's another problem). Ranger says it's a sealed unit that should be replaced for $700 USD, but the manual shows a slew of parts, including standard-sized bearings. The case halves are sealed with silicone and there aren't any indentations or tabs to pry them apart, except for the oil seals at the ends of the pulley shaft. Would it be safe to use some type of separator (and what) to pry it apart from there? The alternative would be to see if a long bolt into the oil fill plug thread has a straight shot to the bottom, but worried about marring the surface of that half.
john.k
Brisbane Qld Australia
Some sealants (blue /orange silicone) can have mighty stiction.......lift a 700lb gearbox on the sealant alone on a six inch square selecter top .......once you break one edge they generall come easily
R
Relax
GTA, Ontario
Decided to brute force it with a razor blade and gently hammering. This will take a while. Based on how much extra sealant oozed out and dried on the pulley shaft seals, I suspect I'll find a thick layer around the inside edge of the flat surfaces as well.
The Cobbler
can you tap the thru holes to a thread that could push on a stud in the original threaded hole . apply some pressure to help push it apart while you're prying with the razor /knife blades .
once it starts to open it will probably ease up . don't over force it but some gentle pressure would probably help a lot
PCustoms
VT
Funny as I was reading this is exactly what I was going to suggest.
Slip a card in that gap and keep working it. Once your partway around see if you can slip a plastic shim (old cc, Bondo spreader, plastic construction shim) in and work it slowly from there.
Don't force it!
R
Relax
GTA, Ontario
That could be an option, but it would be a last resort. The holes aren't tapped at all on either side of the case - the bolt goes through both halves and a nut is used to fasten. The razor blade seems to be working (slowly). I almost have enough clearance to get my thin flat chisel in there.
john.k
Id insert a sharp screwdriver at one of the lug points .......these are much stronger than the case edge ........worm housing seems the best place to me......once you lift one edge ,the rest will just crack open
R
Relax
GTA, Ontario
I've got some good news and some bad news...
The good news is I got the case apart. @PCustoms recommendation to use a credit card really sped things up. I throw all of my expired cards into my toolbox to be used as scrapers, and once I made enough clearance with the razor blade to get one in, it zipped through most of the sealant like butter since I had a better grip on the larger card and didn't have to worry about marring anything with the plastic. Then prying with the flat chisel got the resto of the sealant apart. I went slow and could hear what I was praying was the sealant coming apart rather than the case cracking.
R
Relax
GTA, Ontario
The bad news is after all that, the upper bearing is fine! Haven't removed the shaft to inspect the lower bearing, but opening this up could have been for nothing. Well, maybe not nothing - the lubricant looks like pudding. I think whoever was in here last used a ton of grease on assembly, then topped it up with the gear oil it's supposed to use. I'll be taking a break now before I reach for the gas can...
PCustoms
VT
Is it just the camera angle and sludge, or are the teeth shallow here?
R
Relax
GTA, Ontario
It will be some special long life grease......and should be replaced with the same
According to the manufacturer, it's supposed to be regular gear oil. Someone else has definitely been in there since it came out of the factory. No manufacturer is going to use that much sealant unnecessarily (they could have probably sealed 3 or 4 units with that amount). Also, the neck of the upper casing shows signs of clamping, possibly how they split the case (clamp around the neck and pressing/drifting the spindle out).
