This is a master cylinder mounting bracket for a Jeep CJ. As you can see, the bottom stud is bent. My thoughts are, clean the threads, and try to see where it's bent. Then put on a nut just a bit shorter than the threads, heat it with a MAPP torch and see if I can straighten it?
(I don't own a welder, but...)
If one were to attempt to remove the stud and replace it with a new one, what would that process look like?
Thanks in advance!
Thanks in advance!
