ideas on removing hose
streetglider
Painesville, Ohio area
I am replacing the EVAP vent solenoid on a 2008 Silverado. No problems until I tried to remove one of the hoses from the canister. I don't want to damage it in any way but while it feels loose, it will not slide off. It looks to me like it might be heat shrink. In the video I saw the hoses were held on by clamps but not this one. Any suggestions?
streetglider
You're right about that but that hose is pretty long and runs somewhere I haven't followed well. I'm working on my back in the driveway and at my size it's not easy sliding around under there! I ws just hoping to go an easier route.
streetglider
That hose runs to a filter that is just ******* by the frame near the catalytic converter. The other side of the canister has a hose attached similarly but the other end has a quick disconnect. I have the whole thing out now and it looks like I have to replace the entire assembly: hoses, filter and the vent solenoid. If I was smart, I would have taken to my local guy who probably would have done it for $50.00 plus parts. LOL
rlitman
Long Island
Its just a host that carries gas vapors. You could splice it with a double ended hose barb, or force a new hose on the barbed ends and gently use clamps. It really doesn't matter, so long as it doesn't leak.
streetglider
I used some light heat and got all of the hoses off. Now I am looking to buy the solenoid and maybe a new filter. Prices range from $50.00 to over $120.00. Thanks for the replies.
Spencer Was Here
Western Michigan
If you perform a Google image search on the terms "vacuum hose removal tool", you'll see some plier-looking tools that fit between the end of the hose and the fitting that when squeezed spread apart.
Something like that may help.
streetglider
I am interested in the "vacuum hose removal tool". I think I would use that fairly often.
I was going to buy the valve with the hoses but it is a bit less expensive now that I am able to reuse the originals. It's an older truck and it seems like everything is going at once! This week alone I needed two air bag impact sensors, this valve and new TPMS sensors as the batteries are going bad.
homebuilt burner
central Wisconsin
I wish I had seen your post earlier. I have done all of those job on my 08 Silverado. I had the Same problem with the same hose. I cut it and used some vacuum line in its place.
