Ideas to heat 2nd floor
tabascokid
Medina County, OH
I just built a 32x46 garage with a 16x46 second floor.
I plan on installing a 80K btu radiant tube heater on the main level, any ideas for upstairs.
I'll be putting my wood working tools on the upper level.
Thanks,
ghnl
Mebane, NC
I installed mini-split heat pumps - one for the garage, one for the 'bonus room'. They work well for both A/C & heat. They do lose heating efficiency when the outside temps are very low (below ~ 20F) and have back up electrical heat. Since the room above the garage is not every day living space I don't worry about trying to heat it on the rare very cold NC day.
dave67fd
Southern NH
Make shure you at least properly size your pipe (for an added heater) and install tap/shut-off provision in your main gas line for the added heater.
In wall (vented) propane heater may be nice or even a gas fired fireplace or even wood. Check with your local restrictions first if applicable.
Bojans
If you are not looking for any type of AC for this upper area I might suggest electric baseboard heaters. Being on the second floor you will have a great deal of heat rising up there and IF you need any extra heat the base board heaters respond quickly and will not blow the sawdust all around like a forced air heater. Plus, they are cheap to buy and fairly economical to run if it is just for occasional use.
I know my setup is different given that I use a regular forced air furnace, but with my 15' ceilings and a 52" ceiling fan going constantly my storage loft gets to over 75 when the rest of the garage is 60.
T
tabascokid
Medina County, OH
Thanks, I'm getting ready to start insulation and hopefully get drywall done before the end of the year. Most likely experiment this winter and see how much heat actually does rise.
