Worth hundredsI'm mostly a woodworker with woodworking tools and have no machining capabilities, or need to machine the aluminum slab. It seems a waste to cut it up for odd projects here and there. As Ultradog pointed out, a 1" thick chunk of aluminum could be worth hundreds. I guess I should check around for a market.
A Mic6 plate with a bunch of holes in it and studs ground off. Sure it is.....You keep holding out on that.
