Identify these tools please!!!
r_olson_06
SD
The one the top is a carbon scraper.
Sent from my XT1030 using Tapatalk
r_olson_06
SD
The middle one maybe a serpentine tool.
383 240z
Findley Twp. Allegheny Co.
Off of what would I be scraping carbon if I were using this carbon scraper? CJDave.
Not sure what you use them for. I got one with my tool kit when I started tech school. Never used it. I'm sure it is crawling around in the back of one of the bottom drawers of one of my tool chests.
The tops of pistons. Valve faces. Combustion chambers on cylinder heads. Made of spring steel wire with a beveled and sharpened edge on the business end.
Fedwrench
Valley of the sun
If the socket on the middle tool is 7/16 and the handle is offset, I'm guessing older water pump wrench instead of newer serpentine belt tool.
I would say no to the bottom one being for releasing window crank handle clips, it's too thick.
