Identify This Tool
Motorman55
South Jersey
Can you I.D this vintage tool, its approximate age and its originally designed use? When you pull the trigger on the handle a sharp cutting blade pushes out from the other end.
I picked it up at a local antique shop. I use it for a couple things.
Motorman55
South Jersey
is the gick on the business end of it sticky? as in plant juice?
I'm going with pruning device too.
No, it was dry when I found it. But the blade was stuck open due to a bent shaft that I straightened out to make it operational. I also sharpened the blade with a file.
Motorman55
South Jersey
OK, good guesses.
So here's what I use it for:
1) Cutting/trimming woody/sticker type vines/bushes around the house. Which is probably what its originally made for, but...best yet...
2) It cuts thru old fan belts and mower belts like butter. :thumbup:
Still not sure how old it is as I haven't seen another like it yet.
7th Kahuna
Los Angeles, CA
I don't doubt it's usefulness for pruning, but having looked at a lot of pruning gear through the years, I very much doubt that was it's intended use. Cutting old fan belts is probably closer. Wish I could read the label. I do have an old rose bush I'd like to take it to.
