This mystery tool/metal object was found in a garage, trying to identify what is might be used for and what application it was intended. It appears to be a socket of some sort where and object is inserted and the two prongs can be adjusted/tightened on inserted object. The base is cone shaped on the inside with two screws that can be adjusted to provide support in the socket. The metal ring can slide up and down the prongs to lock/suppressed the prongs or slide back down to release the locking pressure. The other side has a rod with no threading present on the rod or outside of the socket which leads me to believe that it may be related to an electrically socket of some sort. Hope someone out there can identify and tell me what this tool/metal object is and what it was intended to be used on. Any more questions or photos please let me know! Thanks!
