Idiotic Jeep fastener
SteveH - CO
Colorado
1990 Jeep Cherokee. Front disk brake caliper bolts. I can find zero info on the internet. About 7-8mm, shallow 12 point. No known socket I have will even begin to work.
I plan to replaced with the readily-available common fasteners after I get this miserable thing off. Not my truck - helping a buddy.
Is there a special service tool, or just Vise-grips and prayer?
Thank you - Steve
Herzog
Star Valley, Wyoming
For that year (1990) it's not metric. It's just a standard 12 point socket. Probably close to 7/16 or 3/8... but hard tell from the photo (or remember)
Also, this is assuming that's an OEM bolt... been a while but I swear I remember my 1989 having that same bolt head on the calipers.
SteveH - CO
Colorado
I tried every 12 point SAE and metric I own, and they have very little grip and spun easily. I own (of course) 12 point spline SAE, but not metric. I will buy the metric set and see if that's it.
Thanks all!
Herzog
Thanks all!
That's interesting. My gut tells me that's not an oem bolt for that year then. Best of luck!
Firebrick43
West central Indiana
It’s 35 YEARS OLD. Rust has reduced the size of the corners and probably you tried the wrong size first and deformed what was left.
Either wire brush and weld on a nut over the original to get a purchase or use vice grips. It’s already ^*#+#+. Move on and get a new one.
rlitman
Long Island
It looks to me like someone rounded it by hammering the wrong socket on. Shouldn't be difficult to loosen with a rounded nut socket, or a spline socket if you've got one, or even vise grips. Then spend the $2 and replace it.
Can't speak to your model year, but my TJ has 12 point bolts on the wheel bearings. The only 12 point socket I own is dedicated to those, and in all fairness, I kind of like them. So long as you have 12 point sockets, 12 point fasteners are pretty foolproof, until some fool hammers a 6 point socket on them.
SteveH - CO
Colorado
This has 12 pt. wheel bearing bolts, as well, but they are 13mm (far larger), and have a much deeper spline engagement - a 12 point socket fits easily and securely.
These tiny brake bolts are very shallow, so there's very little engagement with the socket.
I'm not against welding a nut onto it, and/or using Vise grips. They will be coming off.
stockerwithalocker
So Cal
Own a few cherokees. That is not the stock caliper bolt, stock they are 6pt hex head. Fyi be aware the threads in the knuckle tend to strip when you re-install that bolt. Check if there is a helicoil there already which may or may not be the stock threads.
NUTTSGT
Northern Central Ohio
A number of places say the correct bolt is M12x1.25x35 10.8 and they are unobtanium from the dealers.
Is that a special thread pitch ?
Shouldn't M12 be either 1.75 or 1.50 ?
oops, ahh I see it now. It's "extra" fine.
Firebrick43
Almost looks like someone put an 12 pt ARP fastener in there.
Probably put this cheap one in there.
What would you expect for a 35 year old vehicle? Plenty of aftermarket parts houses have them and you could always get them from mcmaster carr as they carry that size
RalphInCA
Wine Country, OR
The work of a “helluva salesman”.
Some awesome sales person convinced the engineers working for Jeep at the time that this new fastener system was the best thing ever.
Would save them lots of assembly time/money.
Seemed like a good idea at the time, I guess.
Firebrick43
Its not the stock fastener, its aftermarket
RoninB4
Under My House
-Because the bolt is somewhat of an unknown I would recommend measuring the OD with calipers and getting the thread pitch correct to determine whether this is metric or inch. Winding the wrong thread pitch in there has a high probability of f*cking up the thread and making the job even worse. Would also closely examine the fastener when it's out to see if it has any material in/on the threads. If it's an aftermarket did they get the correct pitch? If not then it may have been cross threaded if there's material or deformed threads. Good luck
mrvm
PA
Not the best choice design for a bolt head but 3 of these bolts secure the hub bearing to the knuckle on my JK. I used a hammer to tap on a 12-point 13mm socket & breaker bar to remove these rusty bolts with little effort. The error some make is using the wrong size socket or 6-point to strip the head of the bolt.IMG_6585.jpeg
stockerwithalocker
So Cal
Perhaps.
But I’ve seen those fasteners on some other car I’ve owned and I thought it was my Jeep.
I remember because I had to go to HF to buy a set of those gosh darn splined sockets.
Used them once.
See my post above, that is not the stock bolt. I’m making the distinction to avoid confusing the OP.
You are thinking of the two top bolts that attach the trans to the motor that are external torx bolts.
Beerhippie
Far NE Oregon
There must be a special place in Hell for every clever engineer who invents new, unnecessary styles of fastener heads.
Locked in a cage over a pool of molten lava with a door held together with nuts and bolts and given a full toolset--except for the one tool that fits those stupid fasteners.....
NUTTSGT
Locked in a cage over a pool of molten lava, held together with nuts and bolts and given a full toolset--except for the one tool that fits those stupid fasteners.....
Yeah, maybe....but I still take pleasure knowing I got to tell a Chrysler/Dodge engineer what he was planning to do on the Dakatoa wasn't going to work in his own factory about 30 years ago.
The look on his face as I slid out from underneath the front of the truck. .... yeah No .... He was convinced it would work and the Dakota assembly line made the change....2 weeks later, back to the original design..... Ha haha ha ... That 20 something year old kid knew what he was talking about over that Engineer with his degree hanging on the wall.
Sorry for the high jack....
Wrench97
Southeastern Pa
You need a set of these.
1747865159977.pngThere are a lot of brands out there some better then others I have a set from Mac tool that work really well even on round heads or broken bolts, hammer one on and remove the bolt
Bigblue&Goldie
My 1984 CJ7 has E-Torx on the Calipers. I think it's the only time I've ever come across E-Torx; for whatever reason my other vehicles don't seem to have them.
lbhsbz
Long Beach CA
Thank you - Steve
That uses an M8x1.25x65mm bolt. 10, 11, or 12mm 12pt should fit. Then get some 6pt bolts somewhere....doesn't need to be anything special, they're under no load whatsoever. I have these in stock but shipping would take a few days.
SteveH - CO
Colorado
Revisiting this. My buddy and I got the old fasteners out with a Vise Grip on the bolt shoulder. This shallow-head bolt is marked '8.8, F-C M8'.
See how shallow the spline area is, compared the hub bearing bolts (which engage easily with a 13mm, 12 point socket). We will be replacing this exotic fasteners with typical 13mm head Jeep caliper bolts and sleeves.
