1320stang
man i bet that thing is Heavy
Can't be too heavy if you can pull it with a dually with a 5th wheel. At least you don't need a semi tractor to pull it.
"the weight is 31,000lbs. Can be pulled with single axle diesel 5th wheel"
31,000 lbs.? I think I would use a semi tractor...just to be on the safe side...![]()
