I'm going for a Mohawk if I can swing it.
AbitNutz
I thought it would be impossible for me to fit a Mohawk A7 due to the height of my garage. I have 127" till I hit the dry wall ceiling. Well, duh, someone pointed out that they ran their line through the rafters. I have an attic above the garage. The access hatch is in the garage All I have to do is make sure the line doesn't hit any wood and run the line up and over through some nicely finished openings....I do believe that it will work.
Rentawrench
Holyoke,Ma. USA
If your going New see how much for the inground kit to run the tubing.
I have an early one an Love it ,but donot have the ceiling height ( yet) .
A
AbitNutz
No, a Mohawk hair style just won't work for me. While I have more hair than Dolly Pardon (grey)...I wear a hat.
SteveU
Congrats, you will love having it. I would also go with the inground kit for the lines if you don't have the room overhead.
Shadowdog500
Down the shore
I love mine.
My lines are run above the rafters because I have an open ceiling and I use the rafters to support the line. You don't have to go that rough either. you can just run them to the ceiling. I saw one with the lines run to the ceiling then forward to the wall, around the car, and back to the other post. I still don't know what he was thinking on that install.
Chris
Strouty
Southern Maine
I think you were talking about the one that Oldcarguy has, it was to clear the bridge crane. That is why I am going in floor, so when my bridge crane is done there won't be any clearance issues from that.
ebfabman
Thats exactly why I put the lines in the floor.
A
AbitNutz
There's no reason I can't run it up into the dry walled ceiling and then across the rafters and down, is there? It seems to be the only good way I can do this.
Hat or no hat...
Shadowdog500
Down the shore
Hat or no hat...
Hell, you can run the lines around the perimeter of your house if you want. Up over the rafters should be no problem.
Chris
A
AbitNutz
Ok, I'm looking for info on the Mohawk A7 and I saw somewhere that it needs 12"s of concrete pad???? I this true? I don't think NORAD has 12"s of concrete over them.
I also can't seem to find all dimensions for the A7. Max height, width, weight, pad thickness, golden goodness.....not really a doc that shows any of that.
WNYflyer
Lockport, NY
Go to the "product support" tab at the top of the Mohawk website. There you will find specs under the architect section and there is also a section on slab requirements.
bill9860
Northern VA
Don't need anywhere near 12" of concrete. Don't have the book handy but I think it is 5" unless they changed spec. I happen to have 8" but that was just my call.
