I'm Hunting For A Boiler.... Need HELP
MR P BODY
I have a 30' X 36' small shop that I just built... I insulated under the concrete
with 1.5" (R9) put the pex in the 6" thick slab... could only insulate down about
8" around the perimeter ..... 3 zones of 1/2" pex, each each about 230' long.
This is a complete steel structure but I did insulate it... 6" roof, 4" on the walls.
I dont want to run a water line under ground to the boiler so I was figuring on
filling the system with water/anti freeze then use a expansion tank for any
growth in the heated water............... can I do this......... next is the boiler,
what size would be correct for this size place...... forgot.... this has 12' walls
I sure would appreciate some help here..... THANKS guys
mcshawnboy
Here's a link for a company with 20+ years EXP. http://www.radiantec.com/index.php?gclid=CJvrv7fs5pwCFQxM5QodaV3DHg & here's an idea worth looking at with energy credits from local, state & federal credits. http://www.sunmaxxsolar.com/evacuated-tube-solar-collectors.php Outlet temps of 130 F is a nice pre-heat starting point! In my area geothermal ground loops are getting popular heating the water to 58 F for free minus installation. This $40 plan from Mother Earth News: http://www.motherearthnews.com/Modern-Homesteading/2003-02-01/Wood-Burning-Furnace-Boiler.aspx or commercial models. Not quite a boiler: http://www.cedartubs.com/chofu-wood.html This fellow by failing developed a whole new generator: http://www.yourownpower.com/Ice/Museum/ Hope this helps you chose! Shawn (Check out this site for hours of entertainment & tech tips!)
:beer:
MR P BODY
My screw up.... I should have stated I was looking for a natural gas unit.... also based
on the info given.... how many BTU input should I be looking for? I' m 30 miles north of
Detroit and I believe the average winter temp to be right around 32*-35* from what I
have checked.... I was thinking about 125,000 btu... am I wrong
thanks
HoosierBuddy
Southern Indiana
I think you're about right on your BTU input.
I went with a tankless modulating boiler that will throttle its input based on the incoming water temperature coming back from the heating loop. It's worked very well.
http://www.nythermal.com/trinity_ti
The ti 150 modulates up to 150,000 BTU. It has an AFUE efficiency of over 95%...which will save you a lot of $ over the life of the boiler.
Phil
MR P BODY
Phil
What kind of price is the 150 TI(round figures).... also did you have to supply
the pump....... do you have any pics of your set up
thanks
