TheEquineFencer
When we rebuilt the shop the last time we expanded the footprint a couple of feet and we found a 30-40 foot well with a 2 inch pipe and well point in it. I put a section of 4 -5 inch PVC around where the pipe came out with plans to install another new pipe and point later on. What I'd like to find is a small fairly low flow water pump to pump water out when I get another pipe in to pump water out to a cooling coil I have that came out of a chiller system. I don't want to pull a LOT of water out with something like a 1/2 HP regular water pump. I figure with the ground water at 55*-60* and the air temp like it is now at 100* outside it'll provide some cooling if nothing else it's take some of the humidity out of the air if I leave it running a while. I'm figuring I'll just use it when the air temp is over 80* outside. a 12VDC pump would be OK as later on I'd like to try to get it off grid with a solar or wind system to charge a battery bank. I'm open to ideas.
