Impact gun Smoking???
choffmann
Perrysburg, Ohio
Okay yall, today I was using my impact gun at work, I noticed it was getting a little war, so I gave it a little break. After a little break I started using it again, then I noticed it was smoking from the vents, any suggestions?
aaronrkelly
southern Iowa
You guys are all big meanies......serious question and you all have nothing but smart *** answers.
..............I suggest stop drop and roll.
:bounce:
Duth62
Airstreaming Around
Damn.Sorry about the dipshit invasion.
Odds are the brushes are shot allowing too much clearance between the commu and giving poor contact, corrosion and heat. What brand and model is it ? Brushes are stupid easy to do....when caught in time. Like NOW.
User_Name
Teegeeack
Take its temperature. When it hits 140 turn it over. At 160 consider it done. Let it sit 10 minutes then serve.
Duth62
Airstreaming Around
It is a ridgid x4 got in 2013
You're under warranty. Even if they "might" require papers you don't have(original receipt) just take it in to a service center. Brushes for most brands are usually <$20 for the pair and a tech can put them in in about 2 minutes flat.
Here's a#
1- 866-539-1710
Jure
Croatia
change the brushes...i fuc_ _ ng hate when one smartass post something then you have 10 other postwhores who are jumping on the bandwagon.
Duth62
Airstreaming Around
I'm not sure Jure. The way it works over here if you put a screwdriver on it and it turns out to be something else( $50 motor) these bastards will deny warranty repair because their little $8 an hour job gives them "authority".
Everyone is on a power trip.
Jure
Croatia
lol then calling a authorized ridgid service seems like a best bet...well it can hurt your pocket and time,but at last you'll still have it covered with warranty :beer:
gungatim
west mich
how much air pressure are you running it on? I've got an air rifle that will smoke if I use the wrong oil, high pressure and flammable oil will give a little 'crack' and smoke out the barrell...but i've never seen an impact do it on regular 100psi air and air tool oil...
bcradio
New Mexico
Check if you can get a warranty repair. If so, it doesn't matter what the problem is as they will fix it.
colin39
Wow the blue smoke of death. Smoking of anysort isnt good, especially in electric equipment. I would recommend either filling it under B1n or w-p-b. Whichever is nearer. Or waxing it?
LordPsychon
In your basement...seriously, go look now!
The Ridgid X4 line was tested in 2014 in one of the major woodworking magazines and though they performed well (a bit of a surprise considering their area of expertise is DIY not woodworking) the magazine noted that they heated up quite a bit after heavy use. That's what kept me from buying into that line.
Kenskip1
Missouri
Now if you had bought a Milwaukee brush less, you would not be in this stimulation.LOL I used to smoke Camels.
Lassen Forge
I could never get them to fit into my smoker...
Going Whole Hog on the project seemed to work, tho...
metaldad
nw indiana
been running power tools for years.
saws, drills, impacts, demo hammers, shell guns, sanders, routers, whatever is corded.
and i aint never had a tool fail because of brushes.
cords, trigger switches, electronics do fail. brushes?
i also repair my power tools, and am a frequent buyer from ere.
