Imperial tools on Metric fastener
Rosso
Scotland, UK
Hi,
Bit of a strange one this, i need a 38mm spanner/wrench for work, along with a 50mm crowsfoot.
I am a professional tech so i tend to only purchase Snap On stuff. I tried a couple of Stahwille crowsfoots/wrenchs but was disappointed that they rusted pretty badly. The finish on them isn't chrome and must have lots of imperfections as they are covered in pin ***** rust spots.
Anyway, a 38mm spanner is over £200, the crowsfoot is £107 !
I can however get a 1.5" wrench which converts to 38.1mm and a 2" crowsfoot which is 50.8mm at a great price.
Has anyone used imperial tools on metric fasteners ? Just wondering if they would work or slip. The crowsfoot is needed for BMW Diff lock nuts which are extremely tight.
rust in the eye
Chicagoland
Fasteners in larger sizes are way less fussy about fit.
You're a pro and wondering if a tenth of a millimeter on a 38mm fastener will make a difference? 8 tenths at 50mm?
These differences are probably within tolerance for the correct mm size wrenches.
Go ahead and buy the imperial size tools
BrandonV
Arizona
A 1-1/2" spanner per the ANSI standards could be anywhere between 38.0 mm and 38.1 mm.
In other words... just fine.
SwissMetric
Switzerland
Once again: Have a look at the table at the end of the Stahlwille catalog. It lists alll common metric and imperial sizes with tolerances and associated thread diameters.
I'd only use mismatched tools where:
1) The difference is so close that it doesn't matter;
Or
2) In cases where the "wrong" socket is tighter due the random tolerance pair.
In all other cases there's a risk to damage the tool and/or bolt/nut.
Typically it's good to have both metric and imperial tools for the most common sizes, at least some sockets and combination wrenches.
garfunkle24
Saskatoon, Canada
I bought a Snap-on 1 7/16" 4-way angle wrench many years ago as they didn't make a 36mm at the time.
After many years of about 50/50 metric and sae, I've pretty much memorised which sizes cross over perfectly (or virtually anway) and which ones are slightly bigger and smaller etc. I will swap out as and when needed.
cherrybomb
Near Madison Wi.
RoninB4
Under My House
-Do I use metric/imperial on each other? Selectively all the time after doing the math for fitment. You're already aware of the 38mm being very close to 1-1/2" but the 2" is, to me, a bit too large for use on a stubborn nut/bolt. With almost 1/32" slop and the amount of force needed I'd be concerned with the corners of the lock nuts deforming and no longer being a true hex. Can you get a machine shop to mill a smaller crow-foot wrench larger for fitment?
mikey03
Here’s what my uncle shared with me he’s no Engineer but it makes sense to me at least
your asking if .1 mm matters at 38 mm size
thats close to 40 which is 4x a 10 mm
divide 0.1 mm by 4
you get 0.025
would 0.025 mm make a difference on a 10 mm fastener? Because as fastener scales so does tolerance since it’s a percent of the size
now your talking 50.8 which is 5x bigger than 10
0.8 divided by 5 is 0.16
would 0.16 matter on a 10 mm fastener? It might so I wouldn’t mess with this esp on a crow foot where your not getting much engagement anyway
but 0.025 on a 10 mm is nothing so I think the 38 mm one is fine honestly
bwringer
Indianapolis
Yup, I've done this many times. Everything I work on is metric, but sometimes a "close-enough" inch tool is more easily available and/or a helluva lot cheaper. (It's 2025, yet metric fasteners are still considered "newfangled" in the US. But that's another rant for another day.)
US-made heavy equipment and farm equipment still uses a lot of inch too, so larger tools tend to be more easily available in inch. Although plenty of Asian and Yurpian equipment is in use over here as well.
As noted above, at large sizes tolerances are such that it usually makes little or no difference.
I think the smallest match I use almost daily is a 5/16" nut driver I stole from my Dad when I was a teenager that I use on 8mm stuff. (5/32" works fine on 4mm, too.) The conversion is so close to exact that it works perfectly well.
Bert_
NW Iowa
I do it as much as possible. I carry the absolute minimum of metric tools. If a standard wrench fits I see no reason to have it in metric.
dcg9381
Austin, TX
I'm the opposite. I have "odd" sizes of metric, like 16mm.
For tough things, you need both.
bwringer
Indianapolis
5/8" = 15.88mm (16mm)
3/4" = 19.05mm (19mm)
13/16" = 20.64mm (close, but doesn't always work on 21mm)
7/8" = 22.23mm (22mm)
15/16" - 23.81mm (24mm)
1-3/16" = 30.16mm (30mm
1-1/4" = 31.75mm (32mm)
1-3/8" = 34.93mm (35mm)
1-7/16" = 36.51mm (36mm-ish; although most tool sets don't include 1-7/16")
Zimbo
Western Australia
I’ve got a few sockets which have both sizes on, as mentioned before, all in the larger sizes.
