dumbandhappy
- Joined
- May 1, 2008
- Messages
- 52
need to buy a 3000K or so winch, seen many of the no name Chinease made winchs on the internet, especailly Ebay for dirt cheap, is a Warn worth it ?
Here's my experience with WARN.
Bought a car hauler 3 years ago. Immediately put a WARN 1700 utility winch on it (~$140 at TSC). Worked great on years 1 and 2. This spring my friend borrowed the trailer. Went to use the winch and heard BZZZZTTT. Water got in the motor housing and toasted the motor. Called WARN and explained the situation. Got a number for a place in Michigan that sells replacement parts. Called them and found out the replacement motor is $181! Yes, that's $40 more than just buying a new winch. Even that guy told me they are designed to be disposable at that price.
Now I am NOT blaming WARN. It clearly states in the owners manual "store in a dry place when not in use." When they work they're a hell of a lot better than a come-along. But if it's going to be exposed to the elements, invest in a cover.
No they are gasket sealed however; you will get some water in them. They are like any other tool, abuse them and they won’t last as long. The earlier post of a winch burning up from rain; I would not say it can’t happen, but; there may have been other factors, so it’s not fair to dispute it. What I can tell you is when I started having problems with my 9500TI Warn (one of the top of the line Warn’s) I opened it up and it was so full of mud (packed tight with mud) I don’t know how it worked, but it did. After seeing the abuse it was put thru and continued to work with limited issues, I won’t buy anything other than a Warn from here out.Guys, how do winches not get water damaged every time some 4X4 crosses a deep stream? It seems like I'm always seeing pictures of trucks/jeeps fording through water almost as high as the top of the hood. Are those Warn winches water sealed or something?
