Gentle_Ben
To the OP. I agree with the others that changing to a different resistance heating method is futile, if the goal is cost savings. It would work better...but it would (in theory) use more electricity to do so.
If you're stuck with what you have, I'd say "insulate, insulate, insulate".
Phil
Thanks for your comments. Yeah from the feedback here it sounds like going to a boiler wouldn't gain me all that much. I might do a few things to improve the efficiency of my hot water tank like adding a tank wrap and adding foam to the copper tubing that comes out of it. As previously mentioned I might move the thermostat to an area that doesn't have the potential to be hit with a draft.
I basically have the maximum amount of insulation that makes sense already. In theory I could add 2 inches of closed cell foam to the outside walls, but I don't know how much that would gain me since I have 2x6 walls with rockwool insulation already and R75 in the ceiling.
I will also shop around for some sort of auxiliary heat I can add to take some load off of the floor heat in extreme situations.
