Improvised tools
Shootinok
Oklahoma USA
If necessity is the mother of invention, it must also be the aunt of improvisation.
When you break a cheap import flex and the small piece that broke off is stuck down next to a spark plug - too tight to get a magnet in there...
A person needs to be creative.
Funnel, tube from a shelf cut-off and a shopvac did the trick
Patent Pending [emoji16]
Sent from my iPad using The Garage Journal mobile app
ChefRex
You gotta do what you gotta do but just maybe if you spent a little more for a quality tool this wouldn't be necessary and you wouldn't have been aggravated and in need of figuring out how to fix your pickle.
Just saying;)
Professional Tool User
BC
Modded and improvised tools have their place when you need to get the job done and don't have time to buy the tool or the tool doesn't even exist.
Now get yourself one or two of these:
https://www.toolsource.com/pickup-t...netic-pickup-tool-p-139194.html?tsqtid=933904
They're super tiny, yet strong, and have saved my bacon and the bacon of techs around me more than once
The only problem with those super magnets is they tend to stick to the things around the path getting to the thing you dropped. I have one on a telescoping stick, and the telescope kept collapsing then the magnet got on a sight spot on the way in.
Pistolero
BC
cant find my Socket welded to a scissor jack. Ill post the pic when i find it
Copymutt
Colorado
Try Five Chevy’s have a weird 5/8 and 3/4 heater hose set up. Needed to accommodate a good seal for both. Made this tubing beader.
Mc817
RI
I've been in a jam like that before. I have some super heavy, tacky grease, and I put a glob of that on the end of something (extension, welding rod, whatever works) and it usually picks up whatever I'm trying to grab
Mgdoug3
KY
I've built several tools when I didn't have the right tool or I could build the right tool far cheaper. I have a side mounted diesel engine stand and sleeve puller that I built that works as well as anything I can buy for the fraction of the price.
