In a pickle with cabinet doors+hinges
Bodj Built
Moorpark, CA
Hey everyone,
I am in the final stages of building built in bookshelves for my wife. I have been putting off making the cabinet doors as long as I can, because I made a bit of a dumb mistake. The fluted trim has a thickness of 3/8", but I should have spaced them off the lower cabinet section an additional 3/8" so they would be 3/4" deep and match the thickness required for the cabinet doors in order to use a standard hinge setup.
My options now include making the cabinet door thinner to match (not ideal in terms of strength and depth required for the mortised Blum hinges), but I imagine I can shim the hinge off the back of the cabinet to not require as deep of a mortise. The plasma table would make quick work of that...
The other option is to make the cabinet door the full 3/4" thickness with a 3/8"x3/8" rabbet so it can be inset into the frame, allowing it to be flush with the fluted trim. This would increase strength, but I don't believe the euro style mortised hinges would work because the rabbeted lip would interfere with the frame when opening.
A post from 20 years ago shows how a gentleman went about this hinge issue, and he included part numbers so it's definitely an option.
Would something like this work as well? It appears to follow the same motion
I believe the biggest issue is getting space between the door and frame when open.
I understand the last two hinges are not designed for a face frame, but I can easily fix that if needed. Before I do that, does anyone have any suggestions for hinges that will easily work with my current setup?
Edit: it actually looks like this will work. Can anyone confirm?
jar944
Northern VA
The 3/8 overlay/rabbet hinges should work.
So would inset doors, just depends on the look you want.
jar944
Northern VA
Which hinge setup are you referring to? I posted three or four options..
Full inset doors are not an option.
I dont think any of ones you listed would work you need a 3/8 lip/inset/ hinge
Like this.
Bodj Built
Moorpark, CA
