borderboy1971
I'm hoping someone can help me with my in floor heat. The shop is 60'x64' with 16' walls. The walls are 8" SIP panels rated at r32, the ceiling is blown in r50. There are 2 14x14 sectional doors rated at r25. There is r9 or r10 2" styro under the slab. (I haven't insulated the foundation wall yet). I put 15 loops of 1/2" pex (300 ft each) within the concrete stapled to the Styrofoam 12" spacing. Concrete is 5-6" thick. The south side wall has 6 3'x3' insulated windows. I believe the shop is extremely well insulated and quite air tight. Outside temps can get to minus 40c here. But typically run minus 20c to minus 30c during January and February. This is my first season with boiler operating and so far with temps down to minus 15c at night it has been ok but seems to use alot of fuel. Right now it burns about 5 gallons of diesel per day. (Due to south windows it pretty much doesn't run at all during the daytime). I'm trying to keep it at 60f. The boiler is a Burnham LE 74000btu that I put in myself. (Don't mind the messy boiler room or shop). I have one steibel pump feeding 15 loops. Can anyone tell me if the boiler is too small, too many loops on one pump, do I need a bypass circuit or is this just the way it's gonna be?
