In wall heating unit for garage
Jr5k
Nj
I have a detached single car garage that is 16X 30. The building is used a workshop/ shed and the interior walls are uninsulated and not sheet rocked/finished. The building has a 100 amp Service. A friend of mine is a retired electrician gave me a Berko FFR- 4824-A in wall heater that he bought for a job that he never ended up using. The unit is brand new still in the box but it was manufactured in 1980. The unit is very basic and when I connected it to test it, it worked fine it has a heat/ fan/ off push button switches. The unit is 240V and 4800 watts. My plan is to connect it with a 30 amp breaker using #10 AWG. I only wish to use the heater while I am physically using the shop as am concerned that I will leave it on and a fire could occur. To address this, I was going to install a 30 amp/240V timer switch to turn on and off the unit, that way if I do forget to turn it off, it will run for 2 hours vs. 3 days. I am not concerned with the unit running for a long period of time, I am more concerned with the safety of having a heater running in a shop un-attended. I did some research on a 30 amp/240 V timer switch and they appear to cost around $200.00. I looked at the newer up to date Berko “hanging” heater units and they cost $500.00. My thought here is that a newer and possibly “safer” with more current safety standards. I would still have the issue of the cost of a 30 amp/240V timer switch costing $200.00. Am I thinking about this correctly or should I consider something else. I have used plug in space heaters in the past and they work, but I am concerned I will leave them on un attended. I live in northern NJ and it can get down to the 20’s (Fahrenheit) in the winter.
Shiftless
East Bay SFO
If you are willing to add a bit more complexity, you could get an inexpensive wall mounted timer switch that activates a heavy duty 30 or 40 amp relay. Parts should be between 50-100.
J
Jr5k
Nj
Thank you. Although I am not an electrician and I did not understand much of the suggestion, I discussed with my friend who is an 84 years young retired electrician. He understood the recommendation and had all of the parts minus the timer. We are going to do the install when I get the timer. Thanks again, it was great to see my friend get all excited drawing diagrams, etc.
