incoming/outgoing pex tubing
Janet Beadle
I've seen design's done both ways does one work better than the other
Out 1 Out 2 Out 3 Return 3 Return 2 Return 1
Out 1 Return 1 Out 2 Return 2 Out 3 Return 3
J
Janet Beadle
No, I'm referring to the manifold should it be out 1, In 1, Out 2, In 2, Out 3, In 3, or should it be Out 1, Out 2, Out 3 and then In 3, In 2 In 1
yeldogt
Reverse return is beneficial when laying out the tubing when you only have two zones in a space.
The manifold is a different animal. Fluids don't act like people think.
J
Janet Beadle
I'm unclear I thought they were all reverse return - my question was simply the order they return should it be for a three run system Out,Out, Out & In, In, IN or should it be Out, IN - Out, IN, - Out, IN just trying to lay out the order correctly and I've seen it done both ways - I'm confused
