tjansson
I've been cutting a number of 1/2-20 threads in alloy steel shaft 33 HRC for some prototype parts at work. I am using a Leblond Regal lathe with DRO. I am using the DRO to bring the cross slide back to "0" after each pass and then advancing the compound slide for the next cut. I keep getting randomly heavy passes, twice now it's blown right through from a 80% cut thread to overcut (too much material removed) and I have to scrap the part. I started engaging the half nut on the same number on the chasing dial each time, but it actually seemed to make the problem worse. I might try cleaning the half nuts and lead screw next.
Any advice? Thanks!
Any advice? Thanks!
