rslaback
I live in a single story ranch home with a completely finished basement. The basement is accessed by an open stairwell in the living room. The majority of the heat of the basement comes from a couple of electric wall heaters but there are also two ceiling mounted drops in the open family room area at the bottom of the steps.
The first floor thermostat is set at 74 degrees and it is comfortable until you go to the basement and then walk up the stairs. I originally thought I had a humidity issue so I did some testing and the humidity is identical at 45% on both floors. The difference is just temperature with the basement sitting naturally around 67 to 68 degrees.
I would like to incorporate some of that cooler air into the HVAC system for upstairs but there are no air returns in the basement, just those two drops. I'm thinking that if I were to add even a vent to the return air side of the furnace in the furnace room that I might see some gain but I am looking for suggestions on how to mix up the air in our home.
