Looking for some experience in this field. I have never had to do something along these lines, not even sure its advisable or doable?
Situation:
I have a amazing 18" Delta Invicta wood planer from the 70's that I need to convert from 3ph to 1ph.
Currently it has a 7.5hp 3ph motor with a 1 1/8" diameter output shaft.
There was a option on this machine to run a 5hp 1ph motor, both 3750rpm.
Because my shop lacks 3ph, and I have researched do a VFD and its cost prohibitive, I am now looking at 5hp 1ph motors for sale.
Finding a 3750rpm, 1 1/8" diameter shaft 5hp 1ph electric motor has proven to be hard and expensive. BUT.. finding a 7/8" shaft is much more common.
Question:
Is there a easy or known way to convert a keyed 7/8" shaft to a 1 1/8" shaft?
Will this adversely effect the motor/machine?
Does it make sense to have one made?
Cost:
I can locate a 5hp Leeson w 7/8" for $250-300
1 1/8" for $500+
Reference:
Delta Invicta RC-51 18" planer
http://www.toolpartsdirect.com/delta-22-460-model-rc-51-20-planer.html
Situation:
Question:
Cost:
1 1/8" for $500+
Reference:
