Industrial drum type fan
930dreamer
Amarillo,TX and Stinnett,TX
I'm looking for two industrial drum type fans for my shop, they need real bearings not oil soaked fiber pads. The last smaller one i picked up still works but goes off kilter every few minutes because the oil pad bearings aren't accessible to oil.
4xdog
Santa Fe, NM
I saw a DeWalt-branded drum fan for sale at Costco today. Not gigantic -- probably 32-inch-ish -- but a decent size. I forgot to go back and check the price, but knowing Costco it was a Chinese product at a good price. I got a Stanley-branded fan at Costco for my shop a few years ago and it's been working continuously for probably four years.
Bert_
NW Iowa
An old furnace fan will move as much air as the smaller drum fans. Can usually be had for nothing too.
nadogail
Coronado, CA
Repurposed furnace blowers, you can often get them in exchange for a box of Doughnuts, just make it clear you are not in competition with the shop that took the old furnace out.
Richard D
Texas City, between Houston and Galveston
I have several old belt-drive "whole house" or attic fans I use, way better than the Chinese junk at the big box store. I have got most for free or less than $100. Most run on a 1/4 or 1/3 hp motor, cheap enough to replace if needed. I build them out with plywood, electrical outlets, and a long heavy cord. I use them not only as fans but as a work station.
Still need to put a guard on this one.
PoorUB
Fargo, ND
Again, old furnace fans work great on can be had for free. mount a couple angle iron for feet, and you can buy rotary multispeed switches fairly inexpensively. I have a nice 1/2 HP unit with a three speed switch/motor. If I want to move air around in the shop low speed is plenty, but i can set it in the doorway and crank it too high to exhaust out the shop if I need to. Plus it doesn't take up much room.
andyvh1959
Green Bay WI
I have the squirrel cage fan from my old furnace. I had planned to hang it from the trusses in my new detached garage, and size the pulleys to make it run slow and just move enough air to provide some natural cooling/air circulation. Would I be better to mount casters on it so I can move it around the shop floor instead?
Gutman
ENC
Love my squirrel cage blower.
Finally added a switch yesterday, vice having to pull the plug.
Works great to exhaust welding fumes from the shop and it creates a good breeze to help in the heat.
PoorUB
Fargo, ND
Don't put castors on it, it will just roll away in the wind!
I found a set of four rubber feet I put on mine, plus the rotary switch from Amazon.
andyvh1959
Green Bay WI
Heh, heh, yeah thought about that, should have said I'd use the caster wheels that can be locked like those on a tool cart.
kbs2244
I FOUND MY FURNACE FAN CREATED TOO MUCH OF A BREEZE
i am talking North Illinois 90 degree summer heat
unrestricted input
it just blew too fast
I need less speed and more volume
I went to a slow drum style
greg13
Weedsport, NY
Can't go wrong with Patton fans. I have a 48" at the shop that is 20+ years old, used every day all day long during the summer. On it's second shaft & 3rd set of bearings.
billt460
Lake Havasu City, Arizona
The problem with big fans...... ANY big fans, is they're noisy. There is no way around this. When you start moving a lot of air molecules by having big steel blades smashing into them at a high rate of speed, it's going to make a lot of noise. The higher the RPM they turn, the more noise they're going to make.
All of these larger diameter drum type fans move a lot of air. But they make a lot of noise doing it. I live in Lake Havasu City. One of the hottest cities in the nation. I have my garage evaporator cooled, which helps a lot. I can keep the garage 85 F when it's 115+ F outside. I also have 3 large fans to help move that cool air around. The inside of my garage sounds like a Russian TU-142 Bear Bomber at takeoff power, when everything is up and running. But it's either that...... Or sweat.
matt_i
Disassemble and adapt pillow block bearings? Other than making up the structure the bearings self-align and should provide a long life imo. The big assumption is there's a nominal-sized shaft diameter but I would be a little surprised if it didn't align with either inch- or metric- stock.
cvairwerks
Within hearing distance of Texas Motor Speedway
Our Big Assed Blackjack's move a heck of a lot of air at low sound levels. Running at full speed, you can stand with your head against the guard and have a conversation at normal voice levels.
I've got an acquaintance that has one of the PowerFoil 24 footers in his hangar. Running full speed, you stand under it and use your phone without any problem.
The problem with most of the shop fans, is that the blades are simply bent sheet metal or formed plastic and are not really designed to move air without beating it into submission first.
andyvh1959
Green Bay WI
I plan to use pulleys and belt to slow down the speed of the squirrel cage furnace fan to a range that still moves enough air while being reasonably quiet. The challenge will be getting the electric motor speed reduced to about 4:1 to get the fan speed down. A 1200 rpm motor with a 4:1 reduction in the pulleys will get 300 rpm at the fan, but it remains to find out if that speed is good for moving air in my shop. I could also choose a three speed motor with the pulley setup to get the air distribution I'd want.
billt460
The problem with all of those "Big *** Fans" is the price. $6,000 for a 6' fan? $1,000 @ foot, seriously? I could air condition my entire 1,000 sq. ft. garage for $2,000 less than that fan. The 24' hanger fans are well into 5 digits. Perhaps it doesn't matter if you own a Gulfstream 650 ER. But for the average guy their prices are way too high for someone who just wants to move some air around his shop or garage.
930dreamer
I spotted this in our alley this weekend.
SILVERPLATE
Fort Worth, Texas
I bought one at Costco a few weeks. Found it to be of high quality and does a nice job moving air so far.
