You'll want to watch the video, citric acid is only 1 component, and it's PH is changed by use of sodium carbonate.Basing on 4.c comment, without watching the video.
Citric Acid is no different than Acetic Acid (vinegar), as far as attacking the base metal, not just the rust. Might be weaker, depending on how you mix it up, but still acid. Not an alternative to Evaporust, which only attacks rust. Maybe an alternative to vinegar, naval jelly, phosphoric acid.
First we had RTFM and RTFA. Nowadays the internet has rotted our brains to the point that we have WTFVYou'll want to watch the video, citric acid is only 1 component, and it's PH is changed by use of sodium carbonate.
Material loss is acessed and compared in the video.
I ordered mine from Amazon.^ Least expensive way to buy Citric Acid is bulk at your local food co-op (or "natural" market.) I use it for making jam and in peach pies to keep the filling from turning brown.
I used to swear by molasses. But I found that it was very batch dependent if it worked or not. 50% of the time, the new 5 gallon bucket of molasses did not work for rust removal. Possibly age related? Not sure. I eventually gave up and went with Evaporust.I use feed grade Molasses mixed about 10:1 with water. A 3 gallon jug is <$20 at the feed store and will yield around 30 gallons. It's as effective as Evaporust but works slowly. If you can spare about a month it's a great rust remover and cheap enough that you can fill a big tote for big parts.
My thought also (though you explain it better)Basing on 4.c comment, without watching the video.
Are they assessing it over multiple periods? Acid is still acid...You'll want to watch the video, citric acid is only 1 component, and it's PH is changed by use of sodium carbonate.
Exactly. $30 for a gallon is a bit pricey, but since it's reusable you can stretch a gallon out a long way. A 5 gallon bucket comes out to less than $25/gal. delivered, which doesn't seem bad.I ordered mine from Amazon.
Easier to just click.
Neutralizes the acid but according to video forms monosodium citrate which he uses to remove rust through chelation rather than acid attack (his words not mine). Claims it's similar process that Evaporust uses.So doesn't that just neutralize the acid?
The washing soda neutralizes the acid to obtain a pure chelating agent. In the case of the video however, I don't think he got the ratio correct. The fact that he still loses a very small amount of base metal indicates the solution is still acidic. It should be fairly simple to get it right with some ph testing strips.Basing on 4.c comment, without watching the video.
The price is pretty brutal and it does drop off in effectiveness pretty quickly. For restoring old hand saws which have a ton of surface area, I go through it way too fast.Or just buy evaporust
We are talking about exceptionally small levels here (microns), but I would echo this YT comment:The washing soda neutralizes the acid to obtain a pure chelating agent. In the case of the video however, I don't think he got the ratio correct. The fact that he still loses a very small amount of base metal indicates the solution is still acidic. It should be fairly simple to get it right with some ph testing strips.
1 liter water
100 grams citric acid
Pick one of:
And a healthy squeeze of dish soap
- 40 grams sodium carbonate (aka washing soda)
- 63 grams sodium bicarbonate (aka baking soda)
- 30 grams sodium hydroxide (aka caustic soda or lye)
Here's the formula given in the video in text form in case it's useful to someone:
If you want to give the lye variant a try it's often sold as drain cleaner like here: https://www.amazon.com/dp/B07MQBT4HS?tag=atomicindus08-20.
Lye won't remove rust but it is great at grease and paint removal, particularly when warmDon't search for "drain cleaner", just search for "lye". There are tons of different brands.
The molasses concoction is stickier, so it’s harder to rince off without a lot of scrubbing.If you're removing rust, it's going to flash rust, doesn't really matter how you take the rust off.
I'd bet the difference in how quickly the flash rust appears is more related to (like you said) how fast you rinsed/dried/coated it, or even weather on that particular day... temp/humidity.
