Top of the door, the vinyl is up tight to the header. When the door comes down, the vinyl presses up against the header as it shuts.Is it screwed to the top of the door, or the frame?
Those look great, I looked into the brushes as well, but it's been -20 or so at night here and wanted a simple, quick solution.Not the cheapest solution but certainly close to the best!
ThermoTraks | Seals for Garage Doors
ThermoTraks energy-saving seals for garage doors are available for any size door. Our thermal seals for garage doors are the only option for garages with A/C.thermotraks.com
It seems to work great!I had an insulated garage door installed recently. So I had to check if there was a gasket similar to what you'd installed 35k0, my door doesn't have it.
Just the gasket on the exterior....now I'm considering something like this. Seems like a good idea.
This seems to work well.did something similar on the sides of my doors inside. I need to do the top still as it has a small gap.
Thanks!That's a good idea.
