Inexpensive DRO for mini mill
tlevan03
Chesapeake, VA
Im looking for an inexpensive DRO for my mini mill. I have the WEN mill and if any of you have any experience with them you know how bad the backlash is on the Z axis and its hard to gauge the depth. That is the only axis I feel i need to measure at this time. Theres a bunch of DRO's on amazon and ebay and I was just curious on whos using what. Thank you!
alfadan
Augusta, ks
The little iGaging scales seem to be pretty popular, though I think the display uses a battery.
Cane
Something like this should work. Might have to make or modify the brackets. We used to have some on the Bridgeports. I think they were mitutoyo.
gte718p
Excessive backlash and a DRO don't play well together, especially if you forget where your number is/was at in process of your operation. TPAC tools https://www.tpactools.com/ sells DRO's at pretty affordable prices. I've also dealt with DRO Pros https://www.dropros.com/ but they are a little more pricey than TPAC.
Excessive back lash is a great reason to have a DRO. It doesn't matter where your hand wheel says you are, the reader knows where the work piece or tool actually is.
I recommend the Iguageing scales and Yuri's touchdro
I build the older version several years ago. My build thread is here:
I was very happy with it until I went full CNC.
T
tlevan03
Chesapeake, VA
Thank you for your input. I ordered one of the iGauge to see how that treats me. I may upgrade it at some point to get the other axis'.
gte718p
If you don't go for an integrated solution, be aware they eat batteries, even when turned "off". Either have a stock or take them out after use. If you don't it is incredibly frustrating because the batteries are always dead when you want to use them.
Are they .5 micon glass scales? No, but they worked for me.
