primeweld.com
Hey guys, what do you think about this miata?hyper therm
How much airflow does it require?i've had this one for a while now, works fine. i don't use it enough to justify an expensive one.
Avg salary of GJ $75,000Hey guys, what do you think about this miata?
Garage Journal: Ferrari
I have the same no-touch pilot arc. But mine has an orange case. Opposite to what's shown now.i've had this one for a while now, works fine. i don't use it enough to justify an expensive one.
At this point, I just wanted to do automotive sheet metal repair work. I may never use it again after that except my wife wanted to learn how to do it to cut designs out of sheet metal.Looking for Recommendations for a Plasma Cutter
I am looking to buy a hand held plasma cutter for out in the garage. This will be in my home garage. I already have an oxygen/acet torch for thicker metal. I would like a plasma to cut up to 1/4". I have a nice air compressor that will keep up no problem. Would like a quality unit, but do...www.garagejournal.com
I posted some examples on how well mine cuts 1/4" & 3/16" plate. (On page 2) The consumables were previously used when I started, I cut out all the plate for the cabinet, and I'm still using the same consumables now.
Note: for all the people who recommended hypertherm, not one of them showed how much better they cut.
I will say, I wish you could get extended tips/scarfing tips for them like the hypertherm. Or if you're planning on running a fab shop or a plasma table then perhaps you'd want a hypertherm. But for a home shop the difference ain't worth the $$
They all work amazing on sheet metal, use a straight edge whenever you can!At this point, I just wanted to do automotive sheet metal repair work. I may never use it again after that except my wife wanted to learn how to do it to cut designs out of sheet metal.
Ordered that one last night, supposed to be here tomorrow. (Love Amazon). I kicked myself for not clicking the $20 off box. Still a great price.Plasma Cutter, Pilot Arc BTC500DP 7th Generation 50Amps Screen Display Dual Voltage 110/220V Digital Plasma Cutting Machine (BTC500DP 7Gen 110/220V)
This is the latest top Chinese plasma cutter that is getting the best reviews. Like others have said stay away from Yeswelder. Do your research.
Make a pattern and cut the piece perfectly. I look forward to making sheet metal repairs to the old rusties
