Inexpensive router suggestions
rd65
Granite Falls, WA
My FIL gave me a couple pieces of formica that I am going to use on my workbench tops. Last time I did this I borrowed a router from my brother, this time I plan on just buying something. I recently saw one in my HF email, Hercules I think, for $109. I dont want to break the bank, and I dont want battery powered as I will rarely be using it. What are brands to stay from? Anything on Amazon worth a look or is that Hercules decent?
shawhite
How thick is the material? If it’s just Formica with no backer I would lean towards a palm router like the Bosch Colt. If it has a mdf backer you may want to look for something bigger like a Bosch 1617. I personally like Bosch routers if you couldn’t tell.
R
rd65
Granite Falls, WA
At this point it is just the formica. But I figure if I am going to buy a router I may as well get a full size rig. Right?
The Cobbler
for finishing formica, a small easily handled router is best. if you want to do heavier stuff, really consider 2 tools as they each have sort of different requirements as per size.
In my opinion, there's not really a 1 size fits all here.
shawhite
You can absolutely use a full-size router to flush trim Formica and if I had to only have one router it would be my 1617. But generally this project would be handled by a palm router like the Colt. Either way you are going to run a flush cut bit with a guide bearing
nbpt100
Massachusetts
Inexpensive is usually Harbor Freight.
Cheapest is $59.99
Do not discount used. Especially if you are only going to use it once or twice. Or a handful of times. Look on CL or FBMP in your area. You may get a good brand for less than a HF new.
dnschmidt
Phoenix, AZ
Bosch Colt. Ideal for this application and the price is little different from the HF Hercules you listed and I've actually seen it cheaper than that.
Packard V8
Spokane, WA
Take your best shot at the big box store and I'll mail you a better router for half that price. You can even choose between a small laminate trim or a full-size.
jack vines
tarbellb
Oregon
Ideal all around router is the mid size 1-2hp, definitely don't need a 3hp unless you're building doors and serious series ww. And a trim router is just to limiting.
I've never had much luck finding a good deal on used.
It's all about the depth adjustment usability, that should guide your choice.
Dave455
Sussex, England
Another vote for a dedicated router / trimmer, assuming that’s the use you had in mind.
They are the perfect tool for the job, even a good quality one is relatively inexpensive, and even if you end up with another router at a later date, these are still perfect for the job intended.
I have this Makita, and love it. I’m in the U.K. but these can be had for the equivalent of $63 here so I doubt they are much different in the U.S.
Given the speed routers spin at, and the potential dangers, I wouldn’t personally want to go too cheap on one of these. Same applies for the cutters, so that’s something to budget for too.C9305635-D9DC-4737-AECC-1DFAA307E816.jpeg
dogdog
Trim routers, Bosch ridgid are good
Hf works but keep in mind cheaper routers takes longer time to setup so….. I like my Makita but really wanted that ridgid router for $40 more. They are trim routers.
PoorUB
Fargo, ND
A used Porter Cable 690. At one time they were the bench mark for routers. A used one in good serve will serve you well.
