Inexpensive teardown table?
Jersey Drew
I realized today that I spend a lot of time cleaning up and being very careful with lots of cardboard when i am working on things. So I googled workbench with drain and it turns out they are called tear down tables. The only problem is that I’m finding is that most of them are over $1000. I don’t need anything that heavy duty I just need something to catch oil and brake cleaner and all that stuff.
white91formula
Boston, MA
You can usually find stainless tables with sinks on one side and top area that can drain into the sink on Craigslist for -$200. Used resraunt equipment. Might be worth looking at.
steaks&anvils
Colorado
You can usually find stainless tables with sinks on one side and top area that can drain into the sink on Craigslist for -$200. Used restaurant equipment. Might be worth looking at.
I second this idea. For awhile I was researching the idea of using them for an outdoor patio kitchen/grill area.
There are S.S. counter top and sink combos that are recessed to contain spills. Think about the dish washer area and prep counters/sinks. Most are modular and can be disassembled. If you get just a recessed counter top, you can install a drain yourself.
I attached a few pictures that I grabbed from the web.
With so many restaurants closing, you can probably pick up a sink/counter pretty cheap, liquidation sale/auction etc. Cash and if you can un-install it from the kitchen, you can get a better deal.
Check CL, auction sites and maybe visit a few restaurant supply stores, they sometimes have used sink/counters etc. Just call and ask. If they don't sell them they may be able to tell you who does.
Rarified27
Between PA and NJ
I've seen rubbermaid utility carts with a hole cut in the corner of the top shelf and 5gal bucket on the bottom to catch anything pushed through used as a parts table. Nothing ever falls off or gets lost in a drain because if it goes through the hole, you can still retrieve it from the bucket.
Bagherra
Virginia Beach, VA
Thats not a bad idea either....
Mr_B
Reading
so simple make your own out of some steel plate with return lip fold on back and cut a small v in return fold in the middle and bend the plate ever so slightly along middle and weld the butted cut .
Drill a hole in the back middle line and make bench or adapt existing bench frame so top tilts to back just enough promote self drainage .
Use old plastic oil containers and funnel for holding oil or get more fancy and weld a fitting underneath for hose .
You can even get more basic with just a folded back return and set bench eo fall back and to one end but doesn't work so well with bigger fluid spills
bwringer
Indianapolis
I don't have room for a teardown table. I use a drip pan on my workbench top.
Same. I have a collection of cookie sheets, cake pans, etc. for this exact purpose. You can get pretty large pans intended for use under washers and water heaters, too.
I recently bought a box of "puppy pad" style disposable absorbent pads, and they've been incredibly, almost unexpectedly, useful. $15 for a box of 100 at Costco.
D.Sobek
This guy uses a dog crate liner as a large tray.Go to about 1:00 in the video to see it.
fsae0607
San Fernando Valley, CA
Exactly what I use.
Although that Eastwood table is nice! Just don't have the room :cry:
Relax
GTA, Ontario
Princess Auto in Canada has them every now and then, and usually on sale. Currently out of stock, but here's an example from an old flyer I found online:
VolvoRyan
Kentuckiana, USA
Hilarious! We had a zillion puppy pads left over from our newest puppy.... what aren't these things good for? Not only are they absorbent on top, and non-permeable on the bottom, but (in a pinch) when moving from OH to IN they made great furniture pads for the tool boxes and stuff in the U-Haul. :)
On topic, I have a love affair with the HF polypropylene service carts. Same thing that WEN is selling on Amazon. They're like $100, and surprisingly solid. I have three of them, and they're wonderful for tearing stuff down. Since they're wheeled, you can move them to and fro as priorities change with different projects. I suppose you could just drill a hole in the top shelf and put a bucket underneath.
-Ryan
