DemoFly
Is it possible to get one under $50?
Medium barrel will suffice.
I will probably use it 10 times in my life. But in the present future I have to bust out some bushings on my jeep.What are you using it for. Any sub $50 air hamer, regardless of coo, if going to be fairly lame.
If your breaking tiles up, sure... But for something like automotive you need something decent,
I've got this one. Not sure of COO, but it's been great. And it's $50
http://www.amazon.com/dp/B000VZAENC/?tag=atomicindus08-20
I have to remove the upper bushings on the Dana 30 front axle. The others I am replacing the entire control arm as an assembly.Which bushings?
I've never had luck with an air hammer on control arm/leaf spring bushings. The rubber absorbs too much of the impact.
Before I had a press, I'd drive the inner sleeve out with a ball joint press or rig a length of all thread. Then I took a long skinny flathead or an alignment tool/spud wrench and pry the OD away from the steel and spray lube in between the bushing and steel. Once the whole OD was coated, wedge the driver all the way through and collapse the bushing inside itself like you're trying to turn it inside out. They will pop out and shoot across the shop. I actually still do it this way on leaf springs because its easier than pulling the whole thing and lifting it onto the press table.
Hole saws can work pretty well too if you have enough room. Use a small one so the torque doesn't jam your wrist if it sticks.
