jcarlosmor
- Joined
- Aug 18, 2014
- Messages
- 3
Hello to everybody in this forum.
This is my first post.
I would like to know if someone could provide some information about how to connect the pipe tubing to an unloader valve of an air compressor.
I bought an air compressor pressure switch like this:
http://www.amazon.com/dp/B00F3DFJ32/?tag=atomicindus08-20
As you can see there has four connections molded at the bottom (one at the bottom, and the remaining three at each side). I had used those four connections as following:
1) At bottom, to air compressed tank.
2) At right, to safety bleeding valve.
3) At center, to output for inflating, painting, etc.
4) At left, to manometer.
There is no problem with these four connections as they are pretty straighforward. The problem arises from the isolated bottom connection intended for the integrated unloader valve (near to the plastic gaskets for the electrical cabling in and out).
After attaching an 1/4 OD copper tube to this connection with their appropiate compression fitting (some kind of small copper ring), this valve is leaking air always. It is necessary an explanation about how I hook up the whole system:
My compressor ouput goes to a "T" shaped check valve. One end of this check valve insert itself into the tank. Since this check valve is a "T", the derivation goes to the unloader valve at the pressure switch. When the compressor starts running all the air leaks at the unloader valve in the pressure switch case.
And no, there is no problem with the check valve if you are thinking that maybe it could be a deffective check valve. I know that the check valve is ok after a simple test: If a seal the "T" derivation at the check valve, the compressor air goes directly to the tank filling it ok. I can stop the compressor and then unseal the "T" derivation": the air in the tank does not leak (or return) through this "T" derivation.
So the leaking is at the unloader valve into the pressure switch. How it is supposed that this unloader valve works? I can see a very small pivot that moves with the air, but there is no way of sealing it completely. I could imagine that maybe a small metal ball must be included (which my compressor switch did not include) that when the air is detected -that is, when the compressor is running- the metal ball floats and seal the unloader valve top. Am I right?
Thank you so much for your time and any help in advance.
Regards.
Regards.
