Info on CFL's
ddawg16
S. California
Guys...this is related to the thread "Compact Fluorescent vs Tubes". I started a new thread so you don't have to read through the whole thread to find the info......I know I don't like doing that.
First...the below link takes you to the Wikipedia site which has a lot of good general info on the subject.
Wikipedia Fluorescent Lamp Info
Summerizing some of the info...
The average output for tubes (electronic ballast) is around 50-67 lum/w. CFL's above 13W average around 60 lum/w. Hence, I think for the most part that you can say that a CFL and tube of the same wattage put out 'about' the same light.
RFI noise seems to mostly come from the arc in the lamp. Some is generated in the wiring but if you are using a battery powered radio, it will not be affected.
Tubes put out their light over the length of the tube....hence, you have less issues with shawdows.......two cans with flood CFL's (30W) in them would put out the same amount of light (apx) as one 4' 2 tube light. Shadows could be reduced the higher you get the lights. My in-laws have 8 CFL floods over the kitchen island....there are NO shadows in that kitchen...plenty of light.
The attached pic is some comparison data off the Consumers Reports web site....that you CU.
And the below text is also from there site with a bunch of myth's answered.
Hope this helps..
Compact fluorescent lightbulbs
Don't fall for the common myths about these long-lasting, energy-saving lights
STILL SHINING Several CFLs from GE, Home Depot, and others are lighting our labs after 10,000 hours.
Photo by Michael SmithSwapping regular bulbs for compact fluorescents can save you at least $30 per bulb over a CFL’s life. The latest bulbs are better than earlier ones. Yet the myths burn on. Here are some of the most common misconceptions:
Myth: Finding a recycler is hard.
Reality: You shouldn’t throw used CFLs out with the trash. But Home Depot, Ikea, and some Ace and True Value stores accept unbroken CFLs no matter where you bought them. Wal-Mart sells the most CFLs. A spokeswoman told us the chain was looking into a recycling program, but it didn’t have one as we went to press. You can also contact your public works department or go to www.epa.gov/bulbrecycling.
Myth: Compact fluorescents are pricey.
Reality: Some CFLs now cost less than $2 compared with $9 to $25 in 1999. Several lasted five to 10 times as long as regular bulbs in our tests, and Energy Star versions use up to 75 percent less power. They’re also warranted for as long as nine years. Write the purchase date on the bulb in indelible ink. And save your receipt.
Myth: CFLs produce a harsh blue light.
Reality: Many now light like ordinary bulbs. Those with a 2,700 to 3,000 Kelvin (K) number have a warmer, yellower color; 3,500 K to 6,500 K bulbs emit a bluer or whiter light. Energy Star CFLs must include the Kelvin number on the package as of December. Look for CFLs labeled "soft" or "warm" white for light like an incandescent’s, and choose "bright white," "natural," or "daylight" for whiter light.
Myth: CFLs flicker when they first light.
Reality: That happened in earlier CFLs with magnetic ballasts. New ones use faster, electronic ballasts.
Myth: These bulbs need time to turn on.
Reality: Turn-on is now nearly instant. But most CFLs we tested took about 30 seconds to reach 80 percent of their brightness, and some flood and outdoor lights took 90 seconds or more. That’s why some appear dim at first and aren’t ideal for areas such as closets or stairs.
Myth: CFLs contain lots of mercury.
Reality: Each bulb has a tiny fraction of the mercury in a traditional fever thermometer. Energy Star CFLs will have strict limits by the end of this year.
Myth: Compact fluorescent lightbulbs release mercury as they burn.
Reality: The mercury is sealed inside the glass tubing.
Myth: You need to put on a hazmat suit if you drop one of these bulbs.
Reality: Exposure to broken CFLs can pose a health risk, especially to a fetus or young child. But don’t panic. Open a window, shut off central A/C or forced-air heating, and clear the room for at least 15 minutes as the Environmental Protection Agency recommends. Then follow the EPA’S cleanup guide at www.epa.gov/mercury/spills. And be sure to keep CFLs out of lamps that could easily tip, especially in rooms used often by children or pregnant women.
Myth: CFLs smoke when they burn out.
Reality: Today’s spent bulbs typically flicker, dim, or emit a reddish-orange glow. If one you own smokes or smolders, turn off power to the light and allow the bulb to cool before removing it and taking it to a retailer or other recycler.
Gary S
Bismarck, ND
I'm convinced. I use CFLs just about everywhere I can fit them in. I've always hated the yellow light of incandescent lighting and just love the clean white light of florescent light. I can now run up to 4x the amount of light for the same electrical cost and not have to deal with the heat generated by the wasted power of incandescent.
krooser
Waupaca, Wisconsin
CFL's will be history in a few short years when LED's become more affordable.
This whole push to force us to adopt CFL technology reeks of Big Brother.
tdkkart
Eastern Iowa
Every time the subject of Mercury comes up I remember my grade-school science classes and how we played with mercury for hours on end. Hold it in your hand and play with, immediately followed by going to the lunchroom and eating puke on a tray.
As far as I know, none of my classmates has had any body parts fall off, or have given birth to any fish-headed children??
I was laughing with the owner of the local HVAC shop about it this fall, he put in a new furnace for me and mentioned that he would properly dispose of my old thermostat. I says "yea, right after you break open the mercury vial and play with it on your desk for awhile." :bounce:
He remembered playing with it in science class too.........
cravej
The side effects aren't that obvious, but that's not a good reason to ignore the danger. Being exposed to low levels of mercury can lead to learning problems, poor motor skills and a shortened attention span.
I also played with mercury in science class, but I wouldn't let my children do it.
tdkkart
Eastern Iowa
If you live in any large metropolitan area, just going outside and breathing is probably more dangerous than playing with mercury.........
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
One thing nobody seems to mention: Do not install a CFL into a powered socket. The arcing and sparking you hear as you do are damaging the internal electronics. Make sure the power is off before installing a CFL. Keep a standard old incandescent bulb around to test a socket in a table lamp or on a multi switch circuit.
Papawswrench
Alvin , Texas
I resisted them at first due to the price. Last year I bought an 8-pak at Sams and installed them around the house. All but one are still working after about a year. Incandescants have never lasted so well in my old house. Now I an putting them in all the lights.
sberry
Brethren, Michigan
I use several as nite light type things, some of the small ones burn 24/7 and dont fool with switches to get around. I have 4 outdoors on photo cells, enough to make ones way around without walking in to something.
sneezer41
People's Republic of Mass
I have a couple could be pushing 20 years old. Old u tube side mount ballast, and one globe one that I took out of my old apartment when I moved out. Moved in 1996 and they were not new
Gary S
Bismarck, ND
anyone find a cfl that will work outside in the cold?
Yes, Menards sells outdoor fixtures with 26 watt lamps in them. They come complete with photocells for automatic dusk to dawn lighting. I have them on my house and garage to light my yard. They have worked flawlessly for 4 1/2 winters. I've had nights where the temp was at -25F at dusk and they all lit just fine and worked through the night down to -44F.
Mellotron
Central Oregon
So what's the deal with dimming non-dimmable CFL bulbs? Of course you shouldn't, they are not designed for it. The reason I ask is because I grabbed the tail end of a lighting ad on the radio that said it's really dangerous. Anybody know the danger? Do they overheat and catch fire? Explode into tiny bits of mercury laden shrapnel? Inquiring minds want to know.
Gary S
Bismarck, ND
I'd have to ask why you would dim CFLs. They run so cheap that you might as well run them at full brightness. Replace the dimmers with a switch and enjoy having more light than you ever thought possible with incandescent light.
rinny_tin_tin
Northern Virginia
Too much nonsense these days indeed. The mercury doesn't hurt the fish and seems to help them maintain ballast. Also, remember the days when you could buy Benzine in any old hardware store and how well it cleaned yer parts? Same with MEK - and how you got that cool feeling when it leeched the fat from your hand. We didn't have ANY bugs with DDT, yet the darn tree-huggers took care of that....and the best anti-nausea drug was Thalidomide..but now... As for lead, aint nuthin better for sweating pipes and my car never used to knock..- so what if it makes kids more stupid --all the dumb bastards want to do is make merry and play video games.
Hey, this new inrush of cancers is all because we are living longer - you gotta die of something ..eventually anyway.
cravej
Too much nonsense these days indeed. ......... - you gotta die of something ..eventually anyway.
Liquid mercury isn't very dangerous. If you ingested it, your stomach and intestines won't absorb much of it. Mercury vapor is dangerous. If inhaled, it will quickly get absorbed into your bloodstream and go right to your brain. Then it can impair your vision, your coordination, make you feel numb, give you memory loss.
Or you can just ignore the dangers and aspire for a Darwin Award. :lol_hitti
jh_m5
I have used CFL bulbs for years in my office and home- One word of caution- the electronic ballast type ( 4 pin bulbs) are very problematic re the ballast. THe Ballasts burn out in about 2 years or so and they are expensive to replace. The old style 2 pin bulbs the ballast last forever ( over 18 years so far in my office) with no problems.
Jh
roger55
Fort Collins, CO
I just looked at some LED lights and the lumen output is much lower. PAR38 LED bulbs were at 200 lumens and the CFLs are 1300 lumens.
