Ingersoll Rand Multi Vane? What is it?
cybin
Hellbay, WI
So, I couldn't help myself and bought a mystery tool at a garage sale. Looks like I'm missing a chuck or some special tools.
Only markings on it are:
42676
OAR2N
There is a center piece that is splined and rotates.
Thanks
-Cybin
SuperKid
Indiana
With that little black button near the trigger, it looks like it may be some sort of reversable drill. Can you get a picture of the chuck end?
SuperKid
Indiana
Did a bit of research for you. From what I found, "multi vane" is the model. It refers to the type of motor the drill uses. The reason for the splines is because what you have is a quick change model. IR sells several different heads for your tool. Here are two attachments:
^^^ Notice the splines?
ImportTuner
WOW, you're good .... I was guessing either a drill or impact hammer ... :)
C
cybin
Hellbay, WI
Awesome! Thanks a bunch, I'm going to start to look for the attachments. I got it for $10, so I didn't do half bad.
-Cybin
Junkman
Northeastern CT
-Cybin
You will find out how good of a buy it was once you find out how much the attachments are. I would go back to where you purchased it and ask to see any unidentified tools that they might have. If they had the gun, then they might have the attachments, but not know what they go to.... very common when someone dies and someone else is left with disposing of the garage contents.
C
cybin
Hellbay, WI
Yea, so I found out that IR calls it a modular drill, you can get different heads for the drill. I must have an older modal since i don't think it is reversing.
P33, R33 are the current model numbers. The new ones go for $399 and the heads are also $399 each.
Bummer. Maybe someone on ebay will want it. I went through the rest of the stuff they had and really don't remember anything of the sort available. I'll look into it though.
Thanks guys,
-Cybin
