jspies22
Hi all,
Looking for help with the pressure switch on my Ingersoll Rand SS5 compressor. The switch has been sticking and the compressor continuously runs until max pressure then pops the relief valve if allowed to. After inspecting the 4 contact points I have found them fused together and need to pry them apart with a screw driver (unplugged). I tried filing the points down and put it back together but the problem persists.
While doing this I broke part of the pivoting switch. So I guess I have 2 basic questions. Why do/did the points fuse and what is the best replacement pressure switch for the compressor I have. Also, budget in mind, cheapest best option. I am running 220v 5hp motor with cut in around 80 lbs and cut out about 135 lbs. Used in home garage for multipule different types of projects but nothing professional full time.
I have attempted to attach a few photos cause, let's face it, posts are worthless without pics and looking up a photo to see what I'm talking about takes way too long.
Thanks in advance for all the wisdom.
