Howdy.
(If you don't want to read all below, quick question: How much of a water flow rate restriction will be created if I install either a swing or spring check valve in a 3/4" (1" AquaPEX) line?)
Maybe I am putting far too much thought into this, but here goes...
I bought my current house about a year ago, recently my girlfriend complained to me about how long it took for the bath tub to fill up in the master bath. So I went into the crawl space and discovered that about 50' of 1/2" copper with 5, 90 degree elbows was used to plumb the master bath (the master bath was an addition by the previous owner). So I replaced both the hot and cold pipes with with 1" AquaPEX (about the same I.D. as 3/4" copper), the hot water line is insulated. As you can imagine the flow rate is now vastly improved. This house is supplied by a private well, no municipal water.
The issue now is that in the morning or when the hot water has not been used for a while, we are dumping a lot of water down the drain waiting for the hot water to arrive. I bought a Grundfos stainless recirculating pump and am putting a kit together to run a loop (second insulated 1" AquaPEX) for hot water up to the master bath. A timer will also be installed so that it only runs in the morning and evening when the M.B. gets >90% of its use.
I plan to install a check valve between the water heater and the pump for the hot water loop, either a swing or spring valve. I am curious as to how much the flow rate will be reduced by installing a 3/4" check valve into the hot water line? I don't want to restrict the awesome flow rate I now have too much. Or, should I buy a couple of 3/4-1" adapters and use a 1" check valve to prevent flow rate restriction?
Thanks in advance.
Thanks in advance.
