I bought one a couple of weeks ago, I think it is a good value and the cons are easily fixed. I used to have all three machines on separate carts and a wall cabinet with all of the supplies, this cart gets it all together and mobile.
pros: built heavy, more solid that the 44" box. Holds two gas cylinders for tig and mig. Casters/wheels are decent and standard size for replacement. Top drawer has dividers for mig and plasma consumables. The top platform is sized good, I have a Lincoln mig, tig, and Linde plasma and they have 1-2" space between them. The stickers are vinyl type and remove easily.
Cons: the drawers have a push in latch that is very stiff, needs modified or defeated. The hood compartment is kind of awkward at the very bottom. The back stationary wheels are attached to a plate that then attaches to the cabinet with six screws, I assembled with Locktite but eventually I'll probably run a couple of beads to secure the plate. The tig rod holder only has four spots, I did not use it> There are not enough chord hooks for all three machines, I bent up two extra out of 3/4x1/8 flat and attached where the tig rod holder goes. The platform where the gas cylinders sit does not have any vertical lip so the cylinders could kick out at the bottom, I drilled two holes and ran a small bungee chord around the bottom of the cylinders. My mig had to be spaced up about 3/4" for the spool compartment door to open. The lock only secures the cabinet side, not the drawers or hood compartment.
