jasondavidmann
A lot of good information here. I'm following along as I am planning to build a 16x50 soon in Manitoba. I agree with the comments about a water heater vs boiler.
that is going to be really nice. A couple of thoughts.
- I'd rethink the doors. I'd much rather have a 16 and an 8. Both standard sizes. The 16 gives you lots of options for pulling in at an angle, backing in a trailer, etc. You could also get three vehicles in there when a storm is coming.
- 12ft ceiling will be fine for your purpose and I'd even think about 12 just over the lift using scissor trusses and the rest make it 9-10 tall. Have you ever gotten up on a ladder in your house to work at ceiling height? Even at just 9ft there is an obvious higher temp up there so the higher your ceiling, the more heat you pay for but never feel.
- I think you have planned where your main work bench will be so be sure to have a window there.
Having worked on them for 30 yrs for my living I am a huge proponent of 2 post lifts. They are the one type that let's you do everything you could ever want to do on a car. And they are cheap compared to 4 post and especially if you add in the bridge jacks. But a scissor lift has me intrigued for my own garage. You can't do a trans on a 4 wheel or rear drive car but maybe on a front wheel drive car. A huge advantage for you is they don't need any special concrete in the floor. And you can move it anywhere you want to.
I installed a 10,000 Benpack 3 months ago on 6 inch concrete. When I looked at the web site it said 4 inches
I have in-floor heat and two drains, one for each garage door. I keep it around 50 degrees for the vehicles to melt snow and the drains are nice so excess water has a place to go versus just evaporating and creating excess moisture/condensation in the garage. At that temp, it takes a little while when you have ice and slush dripping off a vehicle anyway, so I prefer the drain as well. If you put the drain in, put in a p-trap.
Yeah on the site is says previous requirements and new requirements and it went from about 4” to needing 12”. Big jump.
Are you sure? I copied this from the 2020 manual for XPR-10 models. It is usually less if you're mounting in a large complete slab. The deeper recommendations are if your mounting area is independent of the rest of the slab.
Installing the Posts
We strongly recommend having multiple people work together to install the Posts.
⚠ DANGER Pay special attention when installing the Posts. If done incorrectly, the Lift could
fall over, potentially causing damage to the Vehicle, the Lift, and injuring bystanders.
Concrete specifications are:
• Depth: 4.25 inches / 108 mm thick, minimum
• PSI: 3,000 PSI, minimum
• Cured: 28 days, minimum
The Concrete floor where you want to install your Lift must meet the following requirements:
• The floor must be a flat, Concrete floor. It must be level; do not install the Lift on a surface
with more than three degrees of slope.
• Do not install the Lift on cracked or defective Concrete.
• Check the floor for the possibility of it being a post-tension slab. In this case, contact the building
architect before drilling. Using ground penetrating radar may help you find the tensioned cable.
A couple things jump out to me.
1. If your doing concrete footers have them pour knee walls coming up about 2' or so from your finished floor.
2. Pour a pad in front of all your roll up doors
3. I'd look at getting some windows in the top panels of your garage doors. I know guys on this website don't like windows but I love the natural light.
Regarding the in-floor heat, I guess my question is are you going to be out there every day? If your not then I would look at another less costly method. I know in floor heat is really nice but unless your working in it every day IMO I don't think it's worth it. A lot of guys on here are installing mini-splits in their builds. With those systems you get heat and AC in one unit. I know we don't get as hot here in Ontario as say the southern US but having AC would really help with our humid summers.
What a great thread this is! I am planning a 30x40 garage build in Timmins Ontario this summer and I need some ideas for stairs into my loft! For some reason i can't see this pictures, can someone send me them?Brick is still back ordered but this picture is to illustrate the pitch of 8/12. I really, really wish I'd have gone with 6/12. My attic space which I'll show in a second has 8'3" of headroom, 6/12 would have only shortened that a little bit, I believe it was going to be about 7'10", that would have been more than enough. I'm 6'3" and can lift my arm above my head now and not touch the trusses.
https://scontent-dfw5-1.**.fbcdn.net/v/t1.0-9/48373994_1155881971247704_4017862289599234048_n.jpg?_nc_cat=107&_nc_ht=scontent-dfw5-1.**&oh=b3ad8a1df6f4524e1483f453c5d89746&oe=5CC4ECAA
Pardon the mess, it is by definition, 'a work in progress'. This picture is to show what I did for the staircase.
https://scontent-dfw5-1.**.fbcdn.net/v/t1.0-9/50080193_1173968229439078_8834503679240306688_o.jpg?_nc_cat=110&_nc_ht=scontent-dfw5-1.**&oh=70e113eb2583f8ad3196367b088f4437&oe=5D009218
https://scontent-dfw5-1.**.fbcdn.net/v/t1.0-9/50294434_1173968269439074_5783117273006866432_n.jpg?_nc_cat=100&_nc_ht=scontent-dfw5-1.**&oh=f62c0c7932a7bbc0a35584013d84c6dd&oe=5CC8F37E
Attic from top of stairs.
https://scontent-dfw5-1.**.fbcdn.net/v/t1.0-9/50221164_1173968322772402_1213757263928360960_o.jpg?_nc_cat=100&_nc_ht=scontent-dfw5-1.**&oh=a14f11f17154f63127b34d2a09d0d32f&oe=5CB3706D
Attic looking back at stairs.
https://scontent-dfw5-1.**.fbcdn.net/v/t1.0-9/50272048_1173968359439065_5849186020481826816_o.jpg?_nc_cat=106&_nc_ht=scontent-dfw5-1.**&oh=6dd2daa39191fd0081baafb9bc5a6ba0&oe=5CD47C9C
I don't know if any of this helps or not but hopefully it does.
I installed an Atlas 12K lift on 4" concrete and used it for many years and never an issue even lifting 9K lb trucks regularly.
I know your plan approved but if you can go wider I would consider it. 32 outside is about 30 inside, sounds big but throw a car or truck open doors and your maxed out, width wise pretty quick especially if you have anything on the wall and I know you want a lift so that will take space. I suspect no one mentioned it prior as we assumed you were doors on the long side. Knowing that your doors are on the short side now, I suspect some would speak up.
I'm doing plans right now doors on short side as well like you and been looking at dimensions a bunch I know I basically get 1 chance with my build so will be trying to go as wide as I can without hurting the look of my home.
And we are started!
