I know this isn't an automotive forum, but the apparent vast spectrum of knowledge here leads me to believe we could build a "Garage Journal" nuclear reactor if we all put our heads together.
Anyway...I'm installing a fiberglas rear deck (engine lid) on my 911. The lid already has threaded inserts in place for attaching the hood to the hinges. Unfortunately, the holes are in the wrong place (different year/model).
Matching up the hinges to the lid, I marked where the holes should be for the new attachments. There is plenty of fiberglas "pad" available where my marks are. I even have access to the backside if I wanted to do nuts/bolts (Note: There isn't enough room to install a shouldered insert from the backside).
Before I go the nuts/bolts route, I thought it would be neat/clean to use threaded metal inserts (similar to the items shown below, but not exactly). The existing inserts look like they were pressed(?) in place...do not appear to be glassed/glued in.
What is the correct procedure for installing threaded inserts to a fiberglas part?
