snickers muncher
Hi guys. I picked up a motion sensor light switch to install in the kitchen. The switch has terminals for the conductors but also has a spot for the ground---which the instructions insist is needed in order to work. This is an old house and the lights still run off of the original wiring which does not have a ground. Just a hot and a marked, re-purposed neutral is present.
My understanding is that these switches are like any other device and require a hot and a neutral in order to work. Is the manufacturer suggesting that I use a ground in place of a neutral for the same function? Can I just run a neutral wire (14 White Solid CU THHN Wire) from the switch to the box in the light fixture to complete the circuit. The wiring is inside of conduit, but the conduit is not grounded. Basically instead of using ground that doesn't exist can I just connect to the neutral used by the light fixture?
Thanks in advance,
John
Thanks in advance,
John
